STP Čistič vstřikovacího systému diesel (200 ml)
Tomáš
Je tento čistič vhodný i pro automobily s filtrem pevných částic?
Re: STP Čistič vstřikovacího systému diesel (200 ml)
http://www.oleje.cz/p/stp-cistic-vstrik ... -ml--18511 Neměl by být problém....
No myslím že zatial najučinnejším je TEC 2000.
Brembo píše:No myslím že zatial najučinnejším je TEC 2000.
ale pomer cena-vykon nieje najlepsí
STP mi vzdy splnilo to co som od neho potreboval
Ked sa v tom niekto vyzna, co je ktory sajrajt zac , prosim, mozno na zaklade zlozenia si vyberie ten 'svoj pravy' .
Btw ten TEC2000 sa predsa len trosku odlisuje zlozenim.
STP diesel injector cleaner
50-100% - 926-141-6 - Hydrocarbons, C11-C14, n-alkanes, isoalkanes, cyclics, <2% aromatics- KEROSINE - UNSPECIFIED - DISTILLATES (PETROLEUM), HYDROTREATED LIGHT, petroleum product
2.5-<5% - 918-481-9 - Hydrocarbons, C10-C13, n-alkanes, isoalkanes, cyclics, <2% aromatics, petroleum product
2.5-<5% - Butanedioic acid, polyisobutenyl derivatives
2.5-<5% - 203-234-3 - 2ethylhexan 1ol, organic, alcohol - Professional use:in coatings,dilution of a concentrate,in functional fluids,in cleaning products
Valvoline™ DIESEL SYSTEM CLEANER
>=90,00-<=100,00% - 918-481-9 - Hydrocarbons, C10-C13, n-alkanes, isoalkanes, cyclics, <2% aromatics, petroleum product
>=5,00-<10,00% - 248-363-6 - 2-Ethyl hexyl nitrate - cetane booster
>=2,50-<5,00% - 203-815-1 - Morpholine, Diethylene oxide
>=2,50-<3,00% - 203-234-3 = 2ethylhexan 1ol, organic, alcohol - Professional use:,in coatings,dilution of a concentrate,in functional fluids,in cleaning products
>=2,50-<3,00% - 203-749-3 - Oleoyl sarcosine - Uses: Foaming agent, cleansing agent, penetrant, emulsifier, antistat, bactericide for cosmetics; corrosion inhibitor
>=0,50-<1,00% - 202-414-9 - 2-(2-heptadec-8-enyl-2-imidazolin-1-yl)ethanol
Pro-Tec DSC Super clean
60-65 % - 265-149-8 - Distillates (petroleum), hydrotreated light, Odourless Kerosene
15-20 % - 203-234-3 = 2ethylhexan 1ol, organic, alcohol - Professional use:,in coatings,dilution of a concentrate,in functional fluids,in cleaning products
10-15 % - 215-535-7 = xylen - Use in:lubricants and greases, polishes and waxes, adhesives and sealants, anti-freeze products and biocides (e.g. disinfectants, pest control products). Other release to the environment of this substance is likely to occur from: indoor use (e.g. machine wash liquids/detergents, automotive care products, paints and coating or adhesives, fragrances and air fresheners), outdoor use as processing aid, indoor use in close systems with minimal release (e.g. cooling liquids in refrigerators, oil-based electric heaters) and outdoor use in close systems with minimal release (e.g. hydraulic liquids in automotive suspension, lubricants in motor oil and break fluids).
5-10 % - 248-363-6 - 2-Ethyl hexyl nitrate - cetane booster
1-5 % - polyolefin amide alkylen amine
Bluechem System super clean
>60% - 919-164-8 - Distillates (petroleum, gasoline), hydrotreated light
10-<30% - 215-535-7 = xylen
10-<30% - 203-234-3 = 2ethylhexan 1ol, organic, alcohol - Professional use:,in coatings,dilution of a concentrate,in functional fluids,in cleaning products
5-<10% - 248-363-6 - 2-Ethyl hexyl nitrate - cetane booster
1-<5% - 274-263-7 - Benzenesulfonic acid, mono-C20-24- alkyl derivs., calcium salts
<1% - 203-625-9 - toulen
<1% - 919-284-0 - Hydrocarbons, C10, aromatics, >1% naphthalene, petroleum product
<1% - isononylphenole, ethoxylised
TEC-2000 Diesel injector cleaner
10-30% - 203-625-9 - toulen
10-30% - 200-661-7 - isopropyl alcohol , isopropanol, Propan-2-O
10-30% - 200-662-2 - aceton
30-50% - 265-184-9 - Kerosine (Petroleum), Hydrodesulphurised 2
1-5% - 248-363-6 - 2-Ethyl hexyl nitrate - cetane booster
<1% - 265-198-5 - Solvent naphtha (petroleum), heavy arom., petroleum product, Kerosine - unspecified
Pro-Tec OXICAT
30 - 35% - 918-481-9 - Hydrocarbons, C10-C13, n-Alkanes, Isoalkanes, Cyclics, < 2% Aromatics
30 - 35% - 203-234-3 - 2-ethyl-hexanol
30 - 35% - 202-859-9 - Benzyl alcohol
Pro-Tec OXICAT
Naposledy upravil(a) sosko dne čtv kvě 31, 2018 13:22, celkem upraveno 1 x.
Leto: Nokian Wetproof
sosko: STP čistič vstriku opravdu funguje,mam vyzkouseno X-krát..
Ahoj NOVON, možeš to prosím bližšie rozviesť ? Ako si to skúšal, naliate do nádrže (v akej koncentrácii), alebo napriamo? Ako boli vstreky zanesené a ako ich vyčistilo, resp. boli rôzne hodnoty diagnostiky pred-po ? Rozmýšľam, ktorú z týchto vodičiek naliať, možno opakovane pre dlhodobé čistenie, ale len do nádrže, na priame prepojenie nemám bunky
Práve na STP som čítal na inách fórach, že je o ničom, predražený petrolej a výsledok pred-po nulový. Koncentráciu píšu myslím 200ml STP do 40-60L nafty, zdá sa mi to slabá koncentrácia, ale čo sa v tom ja prd vyznám. Preto ma zaujal ten Valvoline, ktorý ma iné prísady a koncentrácia je 300ml na 30L nafty a doporučuje sa minimálne 30km dialničná jazda.
Inak používam VIF do každej nádrže v doporučenom množstve, len pre pokoj na duši. Aj keď akurát tiež mám problém s dymivosťou(na emisnej) a slabšie ťahá a viac treba stúpať na plyn. Už som niečo podobné čítal viackrát, aj na tomto fóre. Keď VIF neulejem, auto ide lepšie, je to cítiť proste. Aj s tými čiernymi koncovkami výfukov vs VIF , no proste nie je to vôbec ojedinelé tieto názory/príznaky. Na druhej strane vyrovnávacie dávky sú v norme, olej doliať na interval 10tis km max 1L , auto ma 284tis. a všetko v motore pôvodné, klop-klop. Mechanik mi hovorí, že VIF, ten tak do každej tretej nádrže max ako prevencia.
Preto chcem skúsiť vysadiť a dať palivovému systému očistnú kúru, ale posudzuje sa mi to ťažko, či treba, či nie a ktorými prísadami.
PS: Mal by som sa naučiť skrátiť moje myšlienkové pochody
Takže v podstatě ti co si do nafty přidávají toluen to mají jako levnější variantu TEC 2000.
bylo
je
je
TEC 2000 som skušal pred niekolkými rokmi a výsledok bol velmy dobrý. Ale nedával som ho do nádrže,motor išiel na čistý TEC-postupne sa cez prepad sfarboval,čo u dnešných aut bude problém. TEC tam má vždy poznámku,aby motor išiel len na čistič alebo pridávat do minimálneho množstva paliva.
Ja pridavam 2x STP do prazdnej nadrze a natankujem max 5l nafty
