Olej do arktickej zimy
dttars02
Příspěvek od dttars02 »
Roller blinds are currently suitable for offices , roller blinds are manufactured according to ISO standards High quality roller blinds Image roller blinds get light and have a nice angle of view Roller blinds (roller blinds) with simple modern style design, roller blinds are increasingly popular especially for offices in the workplace, family living rooms, even for the bedrooms.https://thietkerem.vn/cach-chon-rem-cuon-phong-khach/
With simple, solemn and modern features, roller blinds (blinds) are often installed for large glass facades of high-rise buildings, offices, apartments. Model apartment, look very nice.https://www.behance.net/gallery/83459527/rem-cuon-phong-khach?
Roller blinds (roller blinds) work in a way that rolls up and flows down, so the roller blinds (roller blinds) have very good sun protection. Minh Dang cheap roller blinds Latest roller blinds model 2013 - 2014 Structure: made up of roll bars and screens (acting like a rolling door) that can be rolled up or down to help completely block or partially block the light of the room. Cheap roller blinds The creamy white color of the roller blinds makes the space glow Materials for roller blinds are also very diverse: fabrics, hiflex tarpaulins, thin velvet velvet (absolute light suppression), tungsten or thin knit mesh (partial resistance and decoration).https://gab.com/RenvaiBachDuong/posts/102517944367767353
Naposledy upravil(a) dttars02 dne pon zář 23, 2019 9:12, celkem upraveno 1 x.
lefort
Re: Olej do arktickej zimy
Příspěvek od lefort »
Do takových mrazů bych s naftovým autem bez nezávislého topení nebo přídavného ohřevu chladící kapaliny vůbec nejezdil. Minimálně kup vyhřívací "deku" pod vanu, nový aku a modli se...
Olej 0Wxx bude asi nejlepší a do paliva nejdřív (doma) Velfobin kvůli odstranění vody z nádrže, nový palivový filtr a s sebou zimní naftový Vif.
Olej 0w30 s B3 nabízí třeba Ravenol. A když před cestou tam vyliješ ten Mobil, bude to dobrý proplach....
Ještě bych se zaměřil i na převodovku, páč jestli máš manuál, hledal bych 75w (75w80). Ať jde vůbec řadit. Napadá mě taky Ravenol. Třeba. Podle auta....
abc
Příspěvek od abc »
Pitris píše:Olej 0w30 s B3 nabízí třeba Ravenol a když před cestou tam vyliješ ten Mobil, bude to dobrý proplach....
Jestli je možnost, tak bych s tím Mobilem přijel do Norska a teprve tam ho vyměnil, když je nový jak píšeš.
Jak naznačil Pitris, je to dobrý proplach.
Aygo 2022
Auta s dieselovým motorem prodávaná v severských zemích mívají speciální úpravy, např. elektricky vyhřívaný palivový filtr, někdy i nádrž, chráněné palivové vedení, zakrytovaný motorový prostor, silnější akumulátor atd. atd. Tohle samozřejmě nedoženeš. A pokud už nenastartuješ, nebudeš jezdit, protože pomůže jen umístění celého vozu do teplé garáže a výměna palivového filtru. :idea:
Misojogi
Příspěvek od Misojogi »
z toho vyplyva ze si treba pozicat auto s benzinovym motorom :idea:
pripadne dieslove so spominanou specialnou upravou, lebo asi nie je ziaden pozitok ostat so zmrznutym autom
Rusi rozkladali na Sibiri pod motorom ohen ale to by som nedoporucoval, rozhodne nie na dnesnych autach, mozno este propanbutanovy ohrievac
Standardním, v Norsku bohužel neuplatnitelným řešením, je motor vůbec nevypínat.
https://www.ebay.com/sch/i.html?_from=R ... +&_sacat=0
https://www.power-plugs-sockets.com/norway/ hmm
edit-urcite by som nebral do zasoby nasu naftu, ta ich bude viac mrazuodolna.
henta sranda to je jak silikonova vyhrievana samolepka na vanu. neverim ze udrzi olej teply, ale aspon nebude sialene mrazivy.
Naposledy upravil(a) pepoh dne ned srp 18, 2019 17:23, celkem upraveno 1 x.
Pokud to není přímo v nádrži, nemá to smysl.
bio
Příspěvek od bio »
K naftě - v tuto chvíli má česká a slovenská nafta filtrovatelnost 0°C.
Shi
Příspěvek od Shi »
Ravenol má arctic verzi 0w-30, otázka je, zda jde normálně koupit. Jedná se o RAVENOL ALS SAE 0W-30, ALS znamená Arctic Low SAPS.
Podle parametrů jako čerpatelnost při -40 a bod skápnutí je Ravenol SSO 0w-30 lepší volbou než ALS 0w-30. Navíc se Ravenol SSO 0w-30 dá běžně koupit a je to jeden z mála dostupných s A3/B4 a současně API SN ve třídě 0w-30.
Shi píše:Navíc se Ravenol SSO 0w-30 dá běžně koupit....
A je to sakra dobrej olej :wink:
Shi
Příspěvek od Shi »
Trošku pomůže i zimní aditivum do nafty:
http://www.vif.cz/produkty/aditiva-do-n ... mni-3.html
Ten VIF musí být před nalitím do nádrže doma - ne ve vymrzlým autě.
A samozřejmě bude nutná i adekvátně mrazuvzdorná směs nejen do ostřikovače, ale i v chladiči.
PS: Ta směs do chladiče musí ovšem být namíchaná s vodou !! Čistá (nezředěná) nemrznoucí kapalina se použít nesmí.
Nepíšeš nic o tom na jak dlouho tam jedeš a kde budeš parkovat.
Pokud je to na chvíli, tak bych řešil půjčovnu v SR, pokud na delší dobu, tak půjčovnu v místě. Jestli budeš parkovat venku, tak bych tam s ropákem nejel a opět řešil půjčovnu.
Ve finále to může vyjít levněji.
Pokud máš rád dobrodružství a s tou naftou tam pojedeš, tak bych aditivum řešil až na místě podle zkušeností místních. Mimo obydlené oblasti bych se vůbec nepouštěl. To, že něco neumaže olej je ten poslední problém...
