Toyota Auris 2014
Re: Toyota Auris 2014
Why would you say the risk is high? Jiffy Lube, Auto Dealerships and the oil companies have done a good job brainwashing the public that you NEED to change your oil every 3000 miles.
How much do you pay for an oil change? I pay about $18 for the oil and filter and change the oil myself. Currently I have 175k miles on the car. So at 25k miles per change, 7 changes, that adds up to $126. If I change oil every 3k miles, 58 oil changes, that adds up to $1050. I have saved nearly $1000 and have created 180 fewer quarts of oil that needs to be recycled.
Just for comparison, if I, like the majority of car owners payed some else to change my oil at $40 a pop, that adds up to $2320 or over $2000 in savings.
Krousdb is completely correct. 3k mile change intervals are crazy short for today's engines. There is absolutely no reason for it. The oil analysis PROVES that even manufacturer's recommendations of 5000 to 8000 mile changes are conservative. Gotta love marketing and brainwashing.
V USA bežne posielajú oleje na chem. analýzu aby si overili či je daný interval dobrý alebo nie....
http://www.bobistheoilguy.com/forums/ub ... er=2623790
_______________
_______________
Nejspíše proto, aby výrazně zvýšili náklady na výměnu oleje s filtrem v neznačkovém servisu za max. 20 bugs.Návštěvník píše:V USA bežne posielajú oleje na chem. analýzu aby si overili či je daný interval dobrý alebo nie...
ja by som sa tiez prikonil k oleju 0w-30 a vybral si si dobre, 0w-20 je ako zaklad na slpnenie emisii a TABULKOVEJ spotreby,aj ked nie vzdy je s nizkovisk. olejom spotreba prave najnizsia, vid navstevnik
Zdravím, můžu tento olej použít do Aurise 1.6 97kw benzín?
Děkuju za odpovědi.
http://www.eneos.cz/motorovy-olej-c14/e ... 5w30-i132/
Děkuju za odpovědi.
Cau. Ak Toyota predpisuje do tohoto motora olej so snizenou HTHS viskozitou (A5/B5) tak ano. Inak nie
to Pedros: Můžeš, ale.... můžeš i 0w40 nebo 5w40. Při převažujících delších jízdách pod plynem bych dal ACEA A3, při krátkých může být i 0w30 A1/A5. Co se týče intervalu - krátké jízdy po 10-ti, delší do 15-ti tkm. A kdyby si se podíval, už to tu bylo.... http://www.oleje.cz/forum/mot-olej-toyo ... t5315.html
Díky za info, ..teď jsem otevřel manuál k Aurisu a v tech. údajích doporučují olej API SL, SM nebo SN..o normách ACEA tady není zmínka..naopak na tom balení Eneosu není ani zmínka o normách API, ale jen ACEA A5/B5..no čert aby se v tom vyznal..:-/
No otvorit manual ked uz mas olej doma je asi trochu neskoro. Ak pisu API SL,SM,SN tak stacilo vybrat nieco co spomenul Pitris
S tou A5/B5 jazdi skor dochodcovsky styl
...jsem otevřel manuál k Aurisu...o normách ACEA tady není zmínka...
Překvapuje mě obojí, ale to první mi přijde horší......na tom balení Eneosu není ani zmínka o normách API, ale jen ACEA A5/B5...
Jéééj, tak můžu ho teda použít nebo nee..důchodcovským stylem zrovna nejezdím a nerad bych něco pokur.il..mám raději koupit jinej v A3?? Ale vážně..díík..:-/
A3 rozhodne lepsi volba. Sezenes li v SL,nic nepokadis,a treba v 5-40 ...
a rozumne km vymeny.
Pedrosi nevím jaký je tvůj roční nájezd ale kdyby ti to vyšlo tak dej na léto 5w30 nebo 40 A3 a ten Eneos A5 nechej na zimu.
No a čemu se divíš, jiný kraj, jiný mrav, tedy pardon, normy. Přece nebude ENEOS na svých výrobcích pro Evropu uvádět třeba ILSAC. No a Toyota již tradičně pro svoje motory uvádí velmi široký záběr použitelných olejů, prostě se s tím příliš nepářou, takže je lepší, nechat si poradit někde na fóru, třeba právě tady a také podle toho, jak a co převážně jezdíš.... Takto Ti to nedoporučí aní žádné "mazací plány" jednotlivých výrobců olejů. To je jenom pro základní orientaci.Pedros píše:Díky za info, ..teď jsem otevřel manuál k Aurisu a v tech. údajích doporučují olej API SL, SM nebo SN..o normách ACEA tady není zmínka..naopak na tom balení Eneosu není ani zmínka o normách API, ale jen ACEA A5/B5..no čert aby se v tom vyznal..:-/
http://www.eneos.us/wp-content/uploads/ ... t-2014.pdf
